jeremy Posted April 23, 2007 Share Posted April 23, 2007 Ok so my 90 200Tdi is having some fueling problems which I slowly seem to be resolving. Now our trusty Freelander TD4 Auto has decided to do some attention seeking too! The fuel pump in the engine bay which is usually silent is making a lot of gurgling noises, as if air is passing through it, which suggest to me that perhaps the pump in the tank has failed? I've tried booking into the local specialist (not main dealer) who serviced the vehicle just a couple of weeks ago but they are too busy to help (until the end of May) is it worth removing the tank pump to see if its knackered? Or is it likely to be something else? The engine malfunction light is on - will this go out if the problem is resolved or would that need to be reset? Any advice welcome - to have one land rover playing up is frustrating to have one broken down and one thinking about it is bloody annoying! Quote Link to comment Share on other sites More sharing options...
jules Posted April 24, 2007 Share Posted April 24, 2007 Possible the light will need to be reset. the tank mounted pumps are not the most relyable. The tank is easy to get to under the back seat and very easy to replace. (I have not done a td4 one as my racer didn't have the tank mounted pump the front one was moved to the boot were the 250lt tank was but my td5 disco pump has been in and out four times already this year and that simple enough) Jules Quote Link to comment Share on other sites More sharing options...
jeremy Posted April 30, 2007 Author Share Posted April 30, 2007 Possible the light will need to be reset.the tank mounted pumps are not the most relyable. The tank is easy to get to under the back seat and very easy to replace. (I have not done a td4 one as my racer didn't have the tank mounted pump the front one was moved to the boot were the 250lt tank was but my td5 disco pump has been in and out four times already this year and that simple enough) Jules I replaced the fuel pump unit ( a few pennies short of £300 for a genuine one available straight away ) and everything works fine now - the light went out of it's own accord too so job done. Thanks for the helpful advice. Now I just need to sort out my 90! Quote Link to comment Share on other sites More sharing options...
