tedsmart Posted May 15, 2007 Share Posted May 15, 2007 Hi all, I'm about to renew the upper suspension link ball joint gaiter, hopefully the ball joint will be OK when I take it apart so I'll just have to replace the gaiter which has split, as have the majority of all the rubber boots on the 110. Has anyone done this job recently? and what is involved? any info would be great Thanks. Quote Link to comment Share on other sites More sharing options...
white90 Posted May 15, 2007 Share Posted May 15, 2007 I'm guessing you mean the A frame ball joint. If you can get the rubber boot as a separate item then replacing will be fairly easy remove split pin remove castellated nut a few blows to the casting the holds the ball joint should see it free off , lift clear and change the boot. Quote Link to comment Share on other sites More sharing options...
tedsmart Posted May 15, 2007 Author Share Posted May 15, 2007 Cheers! yes thats the one! I was just concerned that there might be some adverse pressure involved in getting it off and back on again Quote Link to comment Share on other sites More sharing options...
white90 Posted May 15, 2007 Share Posted May 15, 2007 no none Quote Link to comment Share on other sites More sharing options...
