dasterdly Posted July 12, 2007 Share Posted July 12, 2007 hello, Has anybody got any of these securing plates ? MRC 9423 +MTC 4049 I am assuming they are galvanised, so that the metal plate ( MTC 5081 ) dosnt react with the ally sides of the landrover cheers... Quote Link to comment Share on other sites More sharing options...
4.6v8lwt Posted July 12, 2007 Share Posted July 12, 2007 Have you got a description of these plates and where they go, would make it easier to help than having to first search the parts books. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted July 14, 2007 Share Posted July 14, 2007 Have you got a description of these plates and where they go, would make it easier to help than having to first search the parts books. Yes, they are galvanised, but just a good coat of paint should stop them from reacting. you could just use some large washers instead of needing the plate. the top late is actually nuts welded to some plate, because you've got to fit it inside the galvanised top body rail, and it's a plain trying to get your fingers in there to hold the nuts while someone else does up the bolts. For those that don't know, the part numbers refer to the "nut plate" brackets that mount inside the rear tub of FFR rovers where the side antenna mounts are fitted. I might have some of the plates in the garage if you want a picture or 2 of them? Quote Link to comment Share on other sites More sharing options...
