callum Posted July 21, 2007 Share Posted July 21, 2007 dont suppose anyone can describe how this is attached to the door. thinking of getting a pair to use on my defender half doors as handles/armrests as they dont have either. not sure how tey're connected though, if its from behind, it might make things difficult. EDIT just to clarify i mean the interior grab handle. cheers callum Quote Link to comment Share on other sites More sharing options...
russ3120 Posted July 21, 2007 Share Posted July 21, 2007 Callum the inner door handles on a disco have 2 bolts holding them on, they bolt from underneath onto small brackets on the door, or are you on about the handle just inside the rear door (load space)? Russ Quote Link to comment Share on other sites More sharing options...
callum Posted July 21, 2007 Author Share Posted July 21, 2007 Callumthe inner door handles on a disco have 2 bolts holding them on, they bolt from underneath onto small brackets on the door, or are you on about the handle just inside the rear door (load space)? Russ http://cgi.ebay.co.uk/LAND-ROVER-DISCOVERY...VQQcmdZViewItem to clarify i mean one of those. if it involves making little L brackets to hold on, then that sounds ok. cheers callum Quote Link to comment Share on other sites More sharing options...
russ3120 Posted July 22, 2007 Share Posted July 22, 2007 Oh now i know which one your on about, the disco has sooooo many grab handles, yes it too is fixed onto `L` brackets and bolted from underneath. russ Quote Link to comment Share on other sites More sharing options...
