jwhitton Posted August 14, 2007 Share Posted August 14, 2007 Before I put my new rear hub inner and outer oils seals in to my 1993 200TDi, wanted to know which way round the seals go. The original 1993 seals I removed did not have the wire rings. The new ones supplied, FRC8221 and FRC8222, have wire rings on the seal. I looks like the new seals should be fitted with both wire rings on the inside of the hubs facing each other. Question is, is this correct way round to install the seals please? Jon Quote Link to comment Share on other sites More sharing options...
Gromit Posted August 14, 2007 Share Posted August 14, 2007 Yes, the lip of the oilseals should face outward. Make sure the lip of the seal is below the face of the hub. Quote Link to comment Share on other sites More sharing options...
jwhitton Posted August 14, 2007 Author Share Posted August 14, 2007 Thanks, just refitted the hub. Will keep an eye open for any leaks. Jon Quote Link to comment Share on other sites More sharing options...
