gruffboy Posted September 27, 2007 Share Posted September 27, 2007 Recently had gearbox fault appear on my dash. 1996 Range Rover 4.6 HSE. Lost drive in forward and revers gear until i rev the engine hard then it clunks into drive. There seems to be no drop in engine revs when i select 'DRIVE' or 'REVERSE'. Auto box, clean fluid can anyone help.......... Quote Link to comment Share on other sites More sharing options...
paintman Posted September 29, 2007 Share Posted September 29, 2007 Have a look at the FAQ section of http://ashcroft-transmissions.co.uk I wonder if you have low fluid level or the filter screen is partially blocked? Many auto box faults can be solved by draining & replacing the fluid and the gearbox filter. Don't know about clearing fault codes though. BUT Ashcroft also make the comment that changing them can cause problems. In your case you have little to lose. Quote Link to comment Share on other sites More sharing options...
