TheBeastie Posted September 29, 2007 Share Posted September 29, 2007 Quickie When fitting NAS plinths to front is it best to just cut the centre hole in the black plastic panel and bolt the plinth through the plastic panel and the front metalwork or would it make life easier later on to cut out a bigger hole in the black plastic panel and fit it over the entire plinth? My only concern with latter is there would be nothing securing the outside edge of the panel but could easily put a self tapper in. It would mean getting to the headlight would avoid removing both plinths. What do others do? Anyway whilst waiting for a response I will get hacking away at the metalwork! Thanks Malcy Quote Link to comment Share on other sites More sharing options...
ibexman Posted September 29, 2007 Share Posted September 29, 2007 QuickieWhen fitting NAS plinths to front is it best to just cut the centre hole in the black plastic panel and bolt the plinth through the plastic panel and the front metalwork or would it make life easier later on to cut out a bigger hole in the black plastic panel and fit it over the entire plinth? My only concern with latter is there would be nothing securing the outside edge of the panel but could easily put a self tapper in. It would mean getting to the headlight would avoid removing both plinths. What do others do? Anyway whilst waiting for a response I will get hacking away at the metalwork! Thanks Malcy checkout website nicks jungle cheers chris Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted September 29, 2007 Author Share Posted September 29, 2007 Thanks He cuts smaller hole in plastic panel. I will do same. Easier to enlarge hole rather than make it smaller Malcy Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted September 30, 2007 Author Share Posted September 30, 2007 That has got the front ones done. Hopefully next weekend I will get the back done Thanks for the help everyone Quote Link to comment Share on other sites More sharing options...
NicTheOrange90 Posted September 30, 2007 Share Posted September 30, 2007 I didn't have to cut any holes, (have the later lights with plugs), but on the front used a black and decker rotary sander thingy to take the plinths down to the correct depth to make no cutting of metal at all. I left the lights in their original places. Obviously headlamp changes mean a few extra self tappers to remove, but not a thing that needs doing every day. Quote Link to comment Share on other sites More sharing options...
