BadBob Posted December 7, 2007 Share Posted December 7, 2007 Hi all Ihave a Disco 2 V 8 does any one know why the small fan in front of rad (air con I think) seems to run all the time once engine has reached running temp air con off I would assume it must have a sensor some where that has gone is this poss? if so any idea where it is or do you think I have some other prob? thanks Quote Link to comment Share on other sites More sharing options...
lynall Posted December 8, 2007 Share Posted December 8, 2007 Just had same fault on my TD5 and it seems when the ecu sees more than 100c it switchs the air con fan on to help cool the engine, but the ecu stays latched on and needs to be reset with a computer. Is the coolant circulating? Mine ran as soon as the engine started and never stopped until the engine stopped. Lynall Quote Link to comment Share on other sites More sharing options...
