Orgasmic Farmer Posted December 18, 2007 Share Posted December 18, 2007 :D :D :D :D Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted December 18, 2007 Share Posted December 18, 2007 You are also fortunate Tony that your batteries are in the middle of your truck so cable runs are moderate. Us poor sods with batteries at the front and winches at the back (soon ) have a 5m cable run Yes but think how much you saved on the front cable!!!!! Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted December 18, 2007 Share Posted December 18, 2007 Was that picture at Culmhead ??Did you get the punch ?? Nope, Didn't get it, Got too it and the brake on the front winch fell apart because someone (me ) didn't tighten the bolt properly!!!!!!! We only had 15mins to get back and most the bits were in the bog so we headed back! Not to worry, We didn't need that punch anyway!!!! Quote Link to comment Share on other sites More sharing options...
smo Posted December 18, 2007 Share Posted December 18, 2007 Welders warehouse are by far the cheapest i found when scouting about this week, they do 35mm & 50mm on their website el-cheapo and can do other sizes too Quote Link to comment Share on other sites More sharing options...
general-confusion Posted December 18, 2007 Author Share Posted December 18, 2007 Steve 90 thanks for the info...that was my next topic ie twin motor wiring specs and set ups ps do you use 1 or 2 battery isolators ? Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted December 19, 2007 Share Posted December 19, 2007 Steve 90 thanks for the info...that was my next topic ie twin motor wiring specs and set upsps do you use 1 or 2 battery isolators ? Depends how much current your isolator will carry. I only have one but its a huge, solid metal lump that is meant for some heavy plant application.If its the little red plastic handle ones you'll need about 25 of them!!!! As far as wiring goes, You can use one albright to run both motors but to be safe (and i think its advisable) I used two. Just wired them with their own 40mm feed from battery to an albright for each motor and it works brilliantly. Quote Link to comment Share on other sites More sharing options...
