warhammer Posted December 29, 2007 Share Posted December 29, 2007 hi, for a p38, my onboard computer is showing "fuel gauge fault"... any suggestion? pls. many thanks Quote Link to comment Share on other sites More sharing options...
Scubaman Posted January 7, 2008 Share Posted January 7, 2008 hi, for a p38, my onboard computer is showing "fuel gauge fault"... any suggestion? pls.many thanks Hi, I'm afraid that it's going to be a tank out job to get at the pump/sender unit as, unlike the classic, there is no access from inside the car. It's possible that it might be a loose connection but most likely the sender unit has packed up (not as uncommon fault on P38's). Mine is playing up too - will only register at all if there is between 1/4 and 3/4 of a tank and only accurate if there is between just under 1/2 and 3/4 full. Otherwise it shows empty. Quote Link to comment Share on other sites More sharing options...
paintman Posted January 7, 2008 Share Posted January 7, 2008 If its any consolation the early EFI Classics don't have the hole in the boot floor so they're a tank off job too! Quote Link to comment Share on other sites More sharing options...
warhammer Posted January 9, 2008 Author Share Posted January 9, 2008 i'll do it, thanks a lot for suggestions. Quote Link to comment Share on other sites More sharing options...
