TheHarv Posted January 8, 2008 Share Posted January 8, 2008 Can anyone confirm which halfshafts are required for a 95 ex-MOD 110 2.5NA? FTC1724 / FTC1725 is listed as from 94 and/or VIN LAxxxx on... BUT FRC2454 / FRC2455 is listed for the 2.5NA Did the mil ones change at the same VIN as the civvies (regardless of engine)? TIA! -- Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted January 8, 2008 Share Posted January 8, 2008 FRC2454 / FRC2455 are for the early drum braked axles, the other ones (FTC1724 / FTC1725) are for disc braked. the disc braked ones are slightly shorter than the drum ones, although if you chop about 1/2" off the end of a drum braked shaft, it will fit into a disc version! (did it on mine, you lose the circlip on the end but i welded my drive flanges on instead) yes, the part numbers change as per civilian vehicles. Quote Link to comment Share on other sites More sharing options...
TheHarv Posted January 8, 2008 Author Share Posted January 8, 2008 Thanks - perfect Quote Link to comment Share on other sites More sharing options...
