Small water loss 300Tdi
streamline
For some months I have found I have had to top up header tank, which is unusual.
Last Friday I find a large wet patch under the vehicle and on investigation there was water on the front left hand corner at the bottom of the block and lip of the sump. This I found strange as I had replaced the water pump gasket not long since for the second time. (This being a well known fault)
Nothing for it, get stuck in, on removing the fan I found water laying in the fan cowling and this had not been there on previos occaisions. A liitle more investigation was indicated. Topping it up and running the engine, water appeared from the plastic plug on top of the thermostat housing.
The O ring HOOray. Regettably not. On undoing the plug with a spanner the top of the plug parted company with the bottom and it was obvious that it had been fractured for some time, That will teach me not to over tighten plastic,
Remove T/stat to aviod damage-- ream out plastic with fie tang-- cut through plastic with pad saw in 4 places on plug circumference avoiding cutting into threads-- carefully chip out plastic between cuts-- clean up housing threads( a 15mm compression stop end turned out to be the right thread)
Insert new plug not overtightening it .
Hope some one fins this help ful
Hello and welcome to the forum,
The plastic plug is also a known weak point as (as you found out) they snap easily. You can get brass ones I believe from a rangerover or Simonr at X-eng does an anodised aluminium one and gives a forum discount as well. search for Simonr on here.
The other common leak on the front of the 300TDi is the P-gasket which is behind the waterpump (not the water pump gasket) a search of the tech archive on here will reveal an excellent thread by Les on how to replace it.
Pete.
editted to add link.
P gasket thread
Hi Pete and thank you for your welcome.
i did not know it was a weak point just thought I was ham fisted. it's been out three time , twice for the P-gasket you mentioned I actually thought it was that
again. If it goes again Iwill put in the ally one you mention.
I must say that I think the problem with the P-gasket is that the securing bolts for it are not up to the weight of the components on the bracket.
Cheers Dave
Pete.
P gasket thread
I did use a stop end to clean upthe thread before I put in the plug, but I dimly recall that some times dissimilar metals may have an adverse effect on one another so I perlaced the plastic one. Thanks any way
replacement plugs can be had in brass from any decent plumbers merchants for about a pound each....
