300 tdi alarm
trogers
Hi all,
What a bummer I just went to my local sainsbury store and when I returned to the landy I tried to open the door with the buttons to no avail.
I opened it with the key to get in and the alarm went off .
Half a dozen tries later I gave up and ran a lead from the battery to the starter solenoid to start the motor and get me home with the little key light on the dash flashing all the way.
Once home I located the emergency number and tried to reset things doing the the lock and unlock procedure the correct amount of times.
My problem is ( got there in the end) that after I reset and open the door the alarm goes of again.
Has anyone got an idea what i'm doing wrong.
Cheers in advance :(
Sounds your fob is out of sync with the alarm so remove the fob battery and then refit it and with the doors unlocked with the key press the lock button on the fob at least four times.. there's more u can, thats just for starters.
Regards
