RangeyRover Posted February 17, 2008 Share Posted February 17, 2008 As it's cold and dark outside And I'm thinking of ways to make my back end articulate more, and also fresh from a visit to donnington show, it struck me that its not hard to make trailing arms with rose joints at the end. I'll have to make the mounts up though, but shouldn't be too hard. So to get back to the question, anyone know what thread size and pitch are the rear trailing arms? Thanks Quote Link to comment Share on other sites More sharing options...
steve_d Posted February 17, 2008 Share Posted February 17, 2008 My parts catalogue gives part NY120041L and describes it as M20 Nyloc. 1987 RRC Steve Quote Link to comment Share on other sites More sharing options...
RangeyRover Posted February 17, 2008 Author Share Posted February 17, 2008 Thanks Steve! off to look for rod ends..... Quote Link to comment Share on other sites More sharing options...
plasticbadger Posted February 17, 2008 Share Posted February 17, 2008 On my build I'm replacing the whole arm with new tube to suit a 3/4" rod end (or use M20 for ease of finding bolts). The original bush tube is then welded to the end of the new tube. For a mount I've made a plate which bolts onto the original 3 holes with a piece of 60mm channel welded onto it to accept the rod end. If you just screw a rod end onto the existing thread it makes the arm too long for this easy mounting route, hence why I'm making all new arms. Total cost for mine approx £40 plus about 4 hours fabrication time. Not bad I think! Quote Link to comment Share on other sites More sharing options...
RangeyRover Posted February 17, 2008 Author Share Posted February 17, 2008 Similar ideas I think, But I'm experimenting with a different style! If it works I'll post up some pics. Incidentally the pitch is 2mm, making the end M20 x 2mm pitch, it was the diameter I didn't know. RR Quote Link to comment Share on other sites More sharing options...
