Comical Engineer Posted February 24, 2008 Share Posted February 24, 2008 Having just fixed the rear wiper, the front ones have now decided to join in the fun and annoy me by refusing to self park. On intermittent, they do 1/3 sweep then stop, then another 1/3 sweep and stop and so on. Continuous wipe is fine except that they don't park in the correct position. What I would like to know is, how easy is it to get at the wiper motor and am I likely to be able to fix it myself or should I just buy another one and be done with it. Thanks Quote Link to comment Share on other sites More sharing options...
cipx2 Posted February 24, 2008 Share Posted February 24, 2008 Try these topics: http://forums.lr4x4.com/index.php?showtopic=15992 http://forums.lr4x4.com/index.php?showtopic=16329 http://forums.lr4x4.com/index.php?showtopic=20286 Edit: OOPS, the links are from Defender area, but it will help you get the picture, there's not much difference. Here's one in Disco area: http://forums.lr4x4.com/index.php?showtopic=15749 The idea is to check/replace the self park switch. Quote Link to comment Share on other sites More sharing options...
scooby Posted February 25, 2008 Share Posted February 25, 2008 ello comical engineer if you need bits mate there's a breakers in weston point with a couple of 200 disco's and a rangie in there yard. not the best breakers i,ve been too but needs must last time i was there (2 weeks ago) they said they were due a 300 disco soon . if you need more info let me know. Quote Link to comment Share on other sites More sharing options...
Comical Engineer Posted February 26, 2008 Author Share Posted February 26, 2008 ello comical engineer if you need bits mate there's a breakers in weston point with a couple of 200 disco's and a rangie in there yard. not the best breakers i,ve been too but needs must last time i was there (2 weeks ago) they said they were due a 300 disco soon . if you need more info let me know. B****r! I was in Runconrn this morning too! Thanks for the info. Next thing is to work out how to get at it without taking half the car apart. Quote Link to comment Share on other sites More sharing options...
