goddstarr Posted July 17, 2007 Share Posted July 17, 2007 hi dont know if any of you have had the same problem but my intermittent seems to do as it like's some times it work's and other times stops half way through and others just works like first speed wondering if this might be the relay or could it be the motor it's self any info would be greatly recived Quote Link to comment Share on other sites More sharing options...
western Posted July 17, 2007 Share Posted July 17, 2007 try the park switch on the motor, I've had this before a new park switch cured it, LR number for park switch is 520160, also avialable from Lucas agents. Quote Link to comment Share on other sites More sharing options...
simonb Posted July 17, 2007 Share Posted July 17, 2007 try the park switch on the motor, I've had this before a new park switch cured it, LR number for park switch is 520160, also avialable from Lucas agents. Its probably the park switch, all intermittent wiper relays use the park switch to trigger them....The contacts snap off inside the switch due to the flex of the button on the drive gear cam. Sometimes they can be temporaily repaired by carefully taking apart and soldering up the fractured brass contact strip. Quote Link to comment Share on other sites More sharing options...
