Mack Posted February 25, 2008 Share Posted February 25, 2008 The owners handbook states that only engine oil meeting certain Ford spec should be used when servicing. There is no choice. Unfortunately the LR dealer (just one here) insists on using Mobil 1 5w-40. This oil meets other Ford specs.....Aparently the only way to get this cleared is to write to the LR customer service. I would not call since I probably won´t understand the English on the phone. The question: does anybody knows if the usually reply? thanks M Quote Link to comment Share on other sites More sharing options...
chris200100 Posted February 25, 2008 Share Posted February 25, 2008 The owners handbook states that only engine oil meeting certain Ford spec should be used when servicing. There is no choice. Unfortunately the LR dealer (just one here) insists on using Mobil 1 5w-40. This oil meets other Ford specs.....Aparently the only way to get this cleared is to write to the LR customer service. I would not call since I probably won´t understand the English on the phone. The question: does anybody knows if the usually reply?thanks M Go to your local ford dealer and buy some Ford oil, It's cheaper that LR stuff and just the same. I used it in my Disco 3 with no problems. Quote Link to comment Share on other sites More sharing options...
disco_al Posted February 25, 2008 Share Posted February 25, 2008 Ford specify 5w/30 in all their engines these days, 5w/40 would be ok, but in the Mobil brand it would cost a bit. Normal 5w/30 semi synthetic from a factors would be fine, expect to pay around the £15 mark for 5 litres. Quote Link to comment Share on other sites More sharing options...
Mack Posted February 25, 2008 Author Share Posted February 25, 2008 Hello dico al Well, that is cheap compared to the equivalent £43 it costs on this side of the planet. Only Liqui Moli has it. regards M Ford specify 5w/30 in all their engines these days, 5w/40 would be ok, but in the Mobil brand it would cost a bit.Normal 5w/30 semi synthetic from a factors would be fine, expect to pay around the £15 mark for 5 litres. Quote Link to comment Share on other sites More sharing options...
alantd Posted February 26, 2008 Share Posted February 26, 2008 Hello dico alWell, that is cheap compared to the equivalent £43 it costs on this side of the planet. Only Liqui Moli has it. regards M Where are you based? Quote Link to comment Share on other sites More sharing options...
Mack Posted February 26, 2008 Author Share Posted February 26, 2008 Santiago, Chile Quote Link to comment Share on other sites More sharing options...
