VA numbers
stripy
i want to get a timing belt kit for my r-reg 300tdi auto disco
the kits run from va 560898
to va 560897
is the number in my vin/ chassis no which is salljgm73wa771954
or is it on the engine no , which is not noted on my v5
or is it somewhere else
cheers john
to va 560897
cheers john
Something wrong there with the numbers on the kit :blink:
Your VIN ends WA771954. It's this part of the number that denotes your individual vehicle and specifies which kit you need.
The kit apparently covers -1 vehicle as it runs from a VIN ending VA560898 to a VIN one digit earlier....???
You'll need a 300Tdi timing belt kit which covers your vehicle's VIN.
Matt
As always, ask and the Tech Archive shall provide :)
The good news is that the range ends at WA748935, so your vehicle does not need a kit, but if you want to change the pulleys then the cheapest way to get all the pulleys and the belt is to buy the little kit (4096), which is what will already be fitted to your vehicle.
good news indeed mr bog
the 2 belt kits that paddocks do have different part numbers for the tensioner & idler
i take it i want from VA 560898 as my last 6 digits end in 771954
cheers john
Yes you want STC4096K, though I am not aware of the tensioner and idler being different between the kits. You should have plain tensioer and idler pulleys (with no lip to retain the belt) and a crank pulley with a lip on each edge to retain the belt, otherwise it is wrong. Bearmach certainly have the right ones, as that is where we get ours from, I don't know about Haddocks.
