Ben Spray Posted March 6, 2008 Share Posted March 6, 2008 Hi all, A mate of mine is building a tomcat, hes using an efi engine out of an ABS equiped rangie, but he will be using a standard servo/master cylinder and so needs a vacuum connection, could someone post a picture up of where the servo pipe connects to the manifold on an efi non abs rangie as hes not sure that the connection is there on the abs one (if he has something to compare it can be drilled/tapped as needed) Cheers Ben Quote Link to comment Share on other sites More sharing options...
SteveRK Posted March 6, 2008 Share Posted March 6, 2008 If the engine is a flapper then there should already be a connection on the left hand side (as stood at the front of the vehicle looking at the engine) of the plenum cover. There are 2 take offs on this side the right hand when looking from the side of the vehicle is for the extra air valve and the left one for the brake servo. If the engine is a MAF with non vacum servo the left take off point will have an approx' 3/4" A/F blanking bolt. Quote Link to comment Share on other sites More sharing options...
Ben Spray Posted March 6, 2008 Author Share Posted March 6, 2008 great thanks Quote Link to comment Share on other sites More sharing options...
