Big Watty Posted March 10, 2008 Share Posted March 10, 2008 Not being a smal person I have problems with the drivers seat being too close to the door - is it possible to move the seat sliders nearer to the centre (It only needs slight adjustment) Has any one done it? Was it successful? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 10, 2008 Share Posted March 10, 2008 Yes and yes. Moved mine into the Defender position. Drill new holes and use an insert for the bolt or do what I did and weld a nut to a small plate and rivet that in place underneath. You'll just have to get used to being a bit further to the left than the steering wheel HTH Mo Quote Link to comment Share on other sites More sharing options...
Top90 Posted March 10, 2008 Share Posted March 10, 2008 Yes, I moved mine into the middle by about 2cm on my 300Tdi. Much more elbow room, but you need to be aware that the steering wheel is a bit off centre and the handbrake can rub your left leg if you bring your clutch food back to rest it on the floor. I just drilled new holes on the seatbox and moved them over. Quote Link to comment Share on other sites More sharing options...
Big Watty Posted March 10, 2008 Author Share Posted March 10, 2008 Many thanks for your replies - I'll just have to get on with it now! Quote Link to comment Share on other sites More sharing options...
