MINESAPINT Posted March 17, 2008 Share Posted March 17, 2008 In an earlier thread Miserableolgit suggested to gain access to the internals of the door pillar I should remove 1 hinge screw top & bottom and insert fine wand through hole to apply Waxoyl. Additionally through drain hole in bottom of pillar which I think I have located under the vehicle about 6mm. Good advice I am sure. Question is, is the door pillar hollow box section or similar? If I remove screw from door hinge is the nut captive? Thanks MINESAPINT Quote Link to comment Share on other sites More sharing options...
jameslwt Posted March 17, 2008 Share Posted March 17, 2008 should be unless it's rusted away! Quote Link to comment Share on other sites More sharing options...
