TheBeastie Posted March 30, 2008 Share Posted March 30, 2008 I currently have a mix of busbars, fuses and relays in my battery box but need to move them out to make way for putting two batteries in. I am minded to try and run a full battery =ve and -ve to a distribution box to be built on the rear bulkhead. The upper vertical part of the bulkhead is just over 6" high. I wondered if anyone has done this and either has some pictures or can recommend where I can get suitable components. I did wonder about the VWP distribution box since it does look reliable, robust and nicely professional but it seems to clamp onto the battery terminal directly and I think it will be a bit crowded down there. My sandwich box experiments to date do not look nearly so neat Any thoughts gratefully received. Thanks - Malcy Quote Link to comment Share on other sites More sharing options...
SteveBo Posted March 30, 2008 Share Posted March 30, 2008 If I were starting mine again I would probably try one of these: http://www.truck-lite.eu.com/Catalogue/Products/111.htm Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted March 30, 2008 Share Posted March 30, 2008 I used a project box to hold some electronics, there's no reason you couldn't put your bus bars and relays in one too. Quote Link to comment Share on other sites More sharing options...
Ben_J85JTY Posted March 31, 2008 Share Posted March 31, 2008 I have used the same box as Luke has to put a distribution box together. I ran a +ve and -Ve battery lead to a fixed post, then seperate wires for each of the 12 fuses I have on the fuse holder. I also fitted the 5 relays reqired in there as well. I then run to the various bits and pieces, mostly from a loom ran inside a couple of metres of convoluted tubing. Its not the neatest, but was fairly cheap and easy to do. Quote Link to comment Share on other sites More sharing options...
TheBeastie Posted March 31, 2008 Author Share Posted March 31, 2008 That looks a good solution. Where do you get such "project boxes" though? I have tried searching and cannot find anything but suspect I am looking for the wrong thing! Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted March 31, 2008 Share Posted March 31, 2008 cheap as chips from maplin, maybe cheaper elsewhere but you'll probably have a maplin near you that has a range of them in stock, mike Quote Link to comment Share on other sites More sharing options...
