TJ101 Posted April 11, 2008 Author Share Posted April 11, 2008 There is a 2nd accessory socket also off this line according to 07MY wiring spec. I think if read it correct, the 1 in rear is 3mm2 cable, the other socket is 2.5mm2. Unfortunately I don't have the veh overview sheet so can't see actual locations. I know it is 865mm from the split from the main harness though! Thanks Dan,, so another in their somewhere,, The rear loom comes up through the wheel box floor, best go and look while its on the lift !! Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 12, 2008 Author Share Posted April 12, 2008 Guys Has anyone found or know where this 2nd accessory socket is The loom from the rear, come down through the wheel arch/box and into the chassis rail, then runs forward !! Quote Link to comment Share on other sites More sharing options...
