TJ101 Posted April 3, 2008 Share Posted April 3, 2008 Just a quick though, before searching for a answer On the 07 110 XS, but probably the same as TD5 Behind the r/hand rear speaker panel, in the back, their is a spare/unconnected multiplug. with black/purple wire,, anyone have a idea what it's function is Clock running Ralph Quote Link to comment Share on other sites More sharing options...
The Badger Posted April 3, 2008 Share Posted April 3, 2008 Just a quick though, before searching for a answerOn the 07 110 XS, but probably the same as TD5 Behind the r/hand rear speaker panel, in the back, their is a spare/unconnected multiplug. with black/purple wire,, anyone have a idea what it's function is Clock running Ralph i reckon the Black is an Earth, and the Purple is permantly Live. Stick a glow screwdrive in it and see if it glows. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 3, 2008 Author Share Posted April 3, 2008 i reckon the Black is an Earth, and the Purple is permantly Live. Stick a glow screwdrive in it and see if it glows. Thanks,, been their, tried that,, Ign on and off Quote Link to comment Share on other sites More sharing options...
western Posted April 3, 2008 Share Posted April 3, 2008 Just a quick though, before searching for a answerOn the 07 110 XS, but probably the same as TD5 Behind the r/hand rear speaker panel, in the back, their is a spare/unconnected multiplug. with black/purple wire,, anyone have a idea what it's function is Clock running Ralph You might be on your own with this as I haven't any wiring diagrams from 1999 Td5 onwards, but I'll check the Td5 diagrams I have got Quote Link to comment Share on other sites More sharing options...
JST Posted April 3, 2008 Share Posted April 3, 2008 Its a Puggy plug, you have to connect him to it to see what happens Quote Link to comment Share on other sites More sharing options...
western Posted April 3, 2008 Share Posted April 3, 2008 can't find any Black/Purple wires in the 1999 Td5 wiring info, Sorry Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 3, 2008 Author Share Posted April 3, 2008 Its a Puggy plug, you have to connect him to it to see what happens Thanks James ,,, Not,, thats helpfull !! Ralph, Gawd know what it does ?? Power on or off. lights, fog, Reveres, brakes light, etc, not a peep !! Were you at Caerwent Sunday ??? Quote Link to comment Share on other sites More sharing options...
western Posted April 3, 2008 Share Posted April 3, 2008 Nope wasn't at Cearwent, was here at home changing the transfer box, will be at the next one & Somerset though as the main colour is Black it must be some form of earth wire. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 3, 2008 Author Share Posted April 3, 2008 can't find any Black/Purple wires in the 1999 Td5 wiring info, Sorry Thanks for looking,, def Black/Purple,, Les,,, do i get a "I beat Western" badge Quote Link to comment Share on other sites More sharing options...
western Posted April 3, 2008 Share Posted April 3, 2008 NO Quote Link to comment Share on other sites More sharing options...
white90 Posted April 3, 2008 Share Posted April 3, 2008 http://forums.lr4x4.com/index.php?showtopic=21345 may help ? Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 3, 2008 Author Share Posted April 3, 2008 mmm, "Accessories fused direct from battery !!" Thanks Tony,, No power from it,, either with the ign/engine on or not,, but would be handy, a deeper look i recon Quote Link to comment Share on other sites More sharing options...
The Badger Posted April 5, 2008 Share Posted April 5, 2008 Just a quick though, before searching for a answerOn the 07 110 XS, but probably the same as TD5 Behind the r/hand rear speaker panel, in the back, their is a spare/unconnected multiplug. with black/purple wire,, anyone have a idea what it's function is Clock running Ralph Ok, not sure if someone has said this already (my computer is a bit series 1 so I can't see all posts at once). Could it be that it is part of the stereo system, Audio left and right? As it could be there so you can connect another speaker to that, and then through into the doors? Just a thought. Try getting an old speaker and just jimmy the wire's into it. If there is no power coming from it then that might be it? Quote Link to comment Share on other sites More sharing options...
Orange Posted April 5, 2008 Share Posted April 5, 2008 mmm, "Accessories fused direct from battery !!" If that's the case and there isn't anything plugged in it, it might not have a fuse in... so you won't get any power to it. I'm a numpty at electrics, though, so you can probably ignore me!! Check the fuse box for empty slots, though!! Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 5, 2008 Author Share Posted April 5, 2008 Ok, not sure if someone has said this already (my computer is a bit series 1 so I can't see all posts at once).Could it be that it is part of the stereo system, Audio left and right? As it could be there so you can connect another speaker to that, and then through into the doors? Just a thought. Try getting an old speaker and just jimmy the wire's into it. If there is no power coming from it then that might be it? 2 points their Badger,, 1 Cable much to heavy for speakers !! 2 Speaker already their fitted with factory supply Def a power supply, just need to find some time, to check the fuse box out, and find a spare unused hole !! But thanks for the input Quote Link to comment Share on other sites More sharing options...
GBMUD Posted April 6, 2008 Share Posted April 6, 2008 Power supply and/or remote for an amplifier and/or base speaker? Did you try it with/without the stereo on? Chris Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 6, 2008 Author Share Posted April 6, 2008 Power supply and/or remote for an amplifier and/or base speaker? Did you try it with/without the stereo on?Chris Amp ?? Base Speaker ?? did i mention, this is for the Defender !!!! Yep stereo was on at the time,, mind you, its not the original LR unit , but does use the org loom etc !! Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted April 6, 2008 Share Posted April 6, 2008 Is an XS top spec? Maybe it's for an accessory (parking sensors don't come on Defenders, do they?) that isn't wired in or made 'live'. Maybe I should just be quiet. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 7, 2008 Author Share Posted April 7, 2008 Sorted, now i have found 10 mins !! It is indeed a "Accessories fused direct from battery" feed from position 2 (Accessory socket) in the under seat fuse box, with a joint connector fixed to the brake servo bracket under the bonnet, somehow, this connector was not making contact, !!! Thanks all for the input ! Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted April 7, 2008 Share Posted April 7, 2008 Tim As I haven't stripped mine down to have a look. What size fuse is it and what size cable. I need somewhere to connect up my PC and screen for my trip in a few weeks. Do you think it'll be man enough for the job? Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 7, 2008 Author Share Posted April 7, 2008 As I haven't stripped mine down to have a look. What size fuse is it and what size cable. I need somewhere to connect up my PC and screen for my trip in a few weeks. Do you think it'll be man enough for the job? Mark, The line is protected by a 20 amp fuse, under the r/h seat, in the main box, If it was me, i would use this feed for a cooler box or the like, in the rear as that's were it terminates, and fit a new fused supply for the PC, direct from the battery box Quote Link to comment Share on other sites More sharing options...
GBMUD Posted April 7, 2008 Share Posted April 7, 2008 That is handy Tim, I wonder if they fitted them to Td5s... Chris Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 7, 2008 Author Share Posted April 7, 2008 That is handy Tim, I wonder if they fitted them to Td5s... Chris Yep,, useful As i have just put in a power lead from the front, down the left hand side, then over to the right hand side, to find Landrover had beaten me to it !! d'oh !! Am guessing, but recon late TD5's would be the same ThreePointFive Is an XS top spec? Yep, Quote Link to comment Share on other sites More sharing options...
DSN Posted April 11, 2008 Share Posted April 11, 2008 There is a 2nd accessory socket also off this line according to 07MY wiring spec. I think if read it correct, the 1 in rear is 3mm2 cable, the other socket is 2.5mm2. Unfortunately I don't have the veh overview sheet so can't see actual locations. I know it is 865mm from the split from the main harness though! As Tim has already sussed, it is 20A fuse. 90 and 110 models should both have these accesory sockets. 130 doesn't. Have been meaning to look at this for ages but not had the time. Anyway at least it was found. Cheers. Quote Link to comment Share on other sites More sharing options...
SteveBo Posted April 11, 2008 Share Posted April 11, 2008 And I've just run an accessory socket feed to the back of my 05 TD5 110 as well. Ho hum, always room for another. Quote Link to comment Share on other sites More sharing options...
