Les Henson Posted April 4, 2008 Share Posted April 4, 2008 Anyone converted a TD5 Disco to springs? What parts did you use and what work was involved? Thanks. Les. Quote Link to comment Share on other sites More sharing options...
cipx2 Posted April 4, 2008 Share Posted April 4, 2008 There's an article on the subject here. Quote Link to comment Share on other sites More sharing options...
freeagent Posted April 4, 2008 Share Posted April 4, 2008 I think Bearmach do a kit... they certainly do one for the P38 Rangie... Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted April 8, 2008 Share Posted April 8, 2008 You need the plate and bar from the std Disco, and the springs of course. It also pays you to have access to a pooter so that you can convince it that it does not have air springs. Otherwise there are a lot of bonging noises coming your way. We have done many of these because the whole business including labour works out at the same cost as one air spring. Quote Link to comment Share on other sites More sharing options...
Porny Posted April 9, 2008 Share Posted April 9, 2008 My mates done it... but can't remember what springs he used. But easy. His Disco is a bit different though as running 235/85/16's and a 2" lift. You also need to have the settings changed on the SLABS module (from air to coil)... which is easily done with the correct kit (I can help with this if needed) Ian Quote Link to comment Share on other sites More sharing options...
