kingrat Posted April 25, 2008 Share Posted April 25, 2008 Can you fill the transfer box without using the filler plug. Mine's stuck in and won't budge even with a 2ft braker bar. I seem to remember that its not possible, but just thought I'd ask. Cheers Paul Quote Link to comment Share on other sites More sharing options...
tuko Posted April 25, 2008 Share Posted April 25, 2008 Yes it can, the inspection cover on the right top can be removed and you can fill the Transfer case till the oil reaches about half way up the gears. Remove the center seat and the seat box cover, then it's only 4 bolts and your in. Todd. Quote Link to comment Share on other sites More sharing options...
bill van snorkle Posted April 25, 2008 Share Posted April 25, 2008 as Todd said. Re the level plug, It was probably refitted and tightened when the tranfercase was hot. It maybe woth trying to loosen it again sometime after a decent run,Further warming of the casing in the vicinity of the plug with a blowlamp or similar will sometimes do the trick. bill. Quote Link to comment Share on other sites More sharing options...
kingrat Posted April 26, 2008 Author Share Posted April 26, 2008 Thanks guys, thats a great help. I'll warm the casing later and just get the oil changed. Paul Quote Link to comment Share on other sites More sharing options...
