disco chancer Posted April 29, 2008 Share Posted April 29, 2008 this is my first post so hello to everyone whilst driving my passenger side trailing arm snapped just to the rear end of the forward bushing just want to know if you have to change both sides together or just the damaged one thanks for any help in advance Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 29, 2008 Share Posted April 29, 2008 Welcome Ouch, I bet you needed some new underwear if that happened at any kind of speed.... As long as the other side is not damaged (bent) then there is no reason to change both, unless you are suspicious of that side for some reason - they don't usually snap unless horribly mangled, never mind on road! Quote Link to comment Share on other sites More sharing options...
andyb Posted April 29, 2008 Share Posted April 29, 2008 As above, not reason to change both, but I would take the oppotunity to 'upgrade' to the fatter rear arms fitted to RR and Defenders. Should be a few about on 'the bay' or here given that quite a lot of people with lift kits have moved to cranked rear arms. Oh and if you do change the arms, probably a good idea to change the bushes while you are there....espcially if it's a 2nd item. HTH Quote Link to comment Share on other sites More sharing options...
disco chancer Posted April 29, 2008 Author Share Posted April 29, 2008 (edited) new underpants i needed a new seatcloth after my bottom tried to chew through it 60mph when it happened thanks for the help Edited April 29, 2008 by BogMonster Naughty words removed Quote Link to comment Share on other sites More sharing options...
Mark Posted April 29, 2008 Share Posted April 29, 2008 Stick your location in your profile, and you may find someone close to you who has one spare... Quote Link to comment Share on other sites More sharing options...
disco chancer Posted May 1, 2008 Author Share Posted May 1, 2008 Stick your location in your profile, and you may find someone close to you who has one spare... thanks mark sorted that tried the bay but no joy does anyone know anything near to me Quote Link to comment Share on other sites More sharing options...
