fender1234 Posted May 6, 2008 Share Posted May 6, 2008 after a bit of roading the other day i noticed a sort of clicking noice when im pulling away, first i thought it was gearbox but now i think it might be cv joint as it seems worse when pulling away and turning does this sound like cv joint? if so, how can i work out which one it is? and is it a hard job? as it doesnt look to bad cheers Quote Link to comment Share on other sites More sharing options...
ebdesignDEFENDER Posted May 6, 2008 Share Posted May 6, 2008 now you are drive with diif lock? Becouse if CV joint is broken you can only drive so.without diff lock car will not start. Quote Link to comment Share on other sites More sharing options...
fender1234 Posted May 6, 2008 Author Share Posted May 6, 2008 no it hasnt gone yet its just somthing is make a noise which doesnt sound healthy Quote Link to comment Share on other sites More sharing options...
ebdesignDEFENDER Posted May 6, 2008 Share Posted May 6, 2008 well..,I think you have to wait theat sound to come off--or you can take off your CV joint rom each side! Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 6, 2008 Share Posted May 6, 2008 If the CV joint breaks, it's possible that it will lock the wheel - with possibly disastrous results. The bits will more than likely wreck the swivel ball etc as well. Jack one front wheel up, turn the steering to full lock (transfer and gear levers in neutral),and spin the wheel. If the joint on that side is badly worn - you should feel it. Les. Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted May 6, 2008 Share Posted May 6, 2008 my cv has been clicking for 2 years but i don't do many miles most of them are off road. and the on road are never far from home. Quote Link to comment Share on other sites More sharing options...
ebdesignDEFENDER Posted May 6, 2008 Share Posted May 6, 2008 Les Henson--has right! Quote Link to comment Share on other sites More sharing options...
