satfighter Posted May 11, 2008 Share Posted May 11, 2008 Dear td4 users, I need your help to make sure my fl is ok. Finally, I tested my 02 fl td4 on motorway yesterday. I reached maximum speed 140 km with 3200 rpm. Is it normal? or do i have any problem ? Waiting your experience. Best Regards, Haluk Quote Link to comment Share on other sites More sharing options...
jules Posted May 11, 2008 Share Posted May 11, 2008 Should do around 105 to 110 mph I would say from memory. but 100mph without a problem Quote Link to comment Share on other sites More sharing options...
Matt S Posted May 12, 2008 Share Posted May 12, 2008 Hi Land Rover say 102mph for a standard td4 (about 165kmh) If you are only getting 140kmh, (about 87mph) seems as though something isn't quite right. When the fuel pump on my 2005 td4 went I could only rev to about 3000rpm, and couldn't accelerate faster than about 75mph on the motorway. Now it's fixed (with a new fuel pump and air flow meter) it will happily cruise at 90 mph - I have never tried to max it out! Just a thought, because I guess there must be lots of other things to consider and maybe it's down to tyre choice or something like that... Cheers, Matt Quote Link to comment Share on other sites More sharing options...
viorelluta Posted May 12, 2008 Share Posted May 12, 2008 Should do around 105 to 110 mph I would say from memory.but 100mph without a problem CAR: Land Rover Freelander Td4 range INSURANCE GROUP: 10-11 CO2 EMISSIONS: 205g/km PERFORMANCE: Max Speed 102mph / 0-60mph 13.2s FUEL CONSUMPTION: (combined) 37.2mpg STANDARD SAFETY FEATURES: Twin front airbags / ABS WILL IT FIT IN YOUR GARAGE?: Length/Width/Heightmm 4382/2074/1828 it is normal to reach about 160km/h, as the 1,8 petrol provides similar power. My 1,8 goes with 160 with no problem - take also into account that the real speed is usually 5-10% lower that the one indicated on board. you can use a portable GPS/navigation equipment to show you the real speed, it is pretty accurate. viorel Quote Link to comment Share on other sites More sharing options...
