chopperman Posted May 11, 2008 Share Posted May 11, 2008 Where do the 20/60/60/30 amp fuses go to on the nearside-forward of engine bulkhead run to? The 3rd one back (60A ) is to the starter sytem. What is the order, left to right, of the yellow relays below the fuse panel in the cab? and where do they go? 2 have the same code the middle which i believe goes to the rear window heater. I`ve eventually found out that the middle one is the rear heater as it does`nt work This all started because the battery has started to go flat quickly as does a new one that i`ve tried. Pulling the the rear 2 fuses in the engine bay takes the the current down from 12A to 3A with the ignition switched off-Any ideas Quote Link to comment Share on other sites More sharing options...
western Posted May 12, 2008 Share Posted May 12, 2008 these should help. yellow relays x 3 below main fusebox in cab left = C44 = heated rear screen centre = C282 = headlights right = C151 = start relay hth Quote Link to comment Share on other sites More sharing options...
