Bigant Posted May 19, 2008 Share Posted May 19, 2008 Hi Guys First of all a big thank to everyone that replied to my last thread, the gearbox is now firmly and correctly attached to the new engine and having taken note all of the advice I was offered the winner or the person that diagnosed the problem correctly was Les Henson. It was all about the alignment of the clutch plate centre. So the problem now is that I can't get the engine to start. I have no spark at any of the plugs, I have checked the points fitted a new dizzy cap changed the rotor arm and even swapped the HT leads for another set that I had. The coil is the one that was previously fitted and was working fine. I have one HT lead running from the centre of the coil and the wire from the distributer is connected to the front connection on the right hand side of the coil as you look at it standing in front of the vehicle. Should there be another wire connected to the coil? I can't find a spare and in theory if there was one it would be hanging around the engine bay. Any advice or suggestions would be welcome as always. Cheers Bigant Quote Link to comment Share on other sites More sharing options...
Gremlin Posted May 20, 2008 Share Posted May 20, 2008 Should there be another wire connected to the coil? Yes, no 12v = no spark, you should have a live ing wire connected to the plus side and the dist to the neg side, if i remember well from my petrol days! Easy check, put a direct live from the battery and crank, then trace back from behind the dash......... Grem Quote Link to comment Share on other sites More sharing options...
Bigant Posted May 20, 2008 Author Share Posted May 20, 2008 Yes, no 12v = no spark, you should have a live ing wire connected to the plus side and the dist to the neg side, if i remember well from my petrol days!Easy check, put a direct live from the battery and crank, then trace back from behind the dash......... Grem HI Mate Thanks for the info, there must be a wire that I have missed or lost during the engine transplant. Regards Bigant Quote Link to comment Share on other sites More sharing options...
