maas Posted May 25, 2008 Share Posted May 25, 2008 Hi all Is it possible to put 5 doors is a 3 doors Discovery 300 Tdi. Anyone tried it before ?? Regards and thanks for any help Maas Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 25, 2008 Share Posted May 25, 2008 Possible, maybe, but easy or cost effective I very much doubt as the body structure is different on the 3 door and I think if you cut the hole for the doors you will find that there is nothing to fix them to! Quote Link to comment Share on other sites More sharing options...
python Posted May 25, 2008 Share Posted May 25, 2008 might be easier to buy m o t failure and rip that to bits, or just use the whole body. Quote Link to comment Share on other sites More sharing options...
maas Posted May 25, 2008 Author Share Posted May 25, 2008 I thing is not necessary to cut the hole , just nead to use back panels from a five door. I was told that some 3 door bodys comes prepared for that, and we can see that in the chassis number by a letter B in the midle. That`s why I am asking if anyone ever tried it before. Thanks for help Regards maas Quote Link to comment Share on other sites More sharing options...
maas Posted May 25, 2008 Author Share Posted May 25, 2008 A bit more info about chassis number mine is SALLJGAF8MA and if you check the body type mine is AF means that is "F = 4 door Crew Cab" and it has only 3 doors. Synopsis of Chassis/Serial Numbering Scheme Digits 1 Geographic Region: S = Europe 2 Country: A = United Kingdom 3 Manufacturer: L = British Leyland/Land Rover 4,5 (model) LB = Series III, Stage I, Lightweight LD = 90 & 110, later Defender LH = Range Rover (mk I) (Classic) LJ = Discovery LN = Freelander LP = Range Rover (mk II) LT = Discovery, Series II 6 (wheelbase) A = 88" & Freelander, & 100" for RR mk I C = 109" and 1 ton G = 100" H = 110" & 147" K = 127" M = Special R = 110" S = Military 110" V = 92.3" 7 (body type) A = Truck Cab, Soft Top or Hard Top (Utility body) B = 3 door Station Wagon, or Freelander 5 door hardtop E = 2 door Crew Cab F = 4 door Crew Cab H = High Capacity pick-up (Some had an A instead of the H) M = 5 door Station Wagon & 7 Door SW R = Monteverdi Range Rover 8 (engine) B = 2.5l, 4 cylinder, Turbo diesel C = 2.5l, 4 cylinder, diesel D = 2.5l, 4 cylinder, petrol F = 200 Tdi & 300 Tdi (2.5 Liter, 4 cylinder, Turbor Diesels) G = 2.25l diesel & Freelander V6 H = 2.25l petrol M = 3.9 liter V8 (injection) P = 2.6l 6 cylinder, petrol V = 3.5l V8 petrol (carburettor) Y = 2 liter T16 petrol Z = 3.9 liter Izuzu diesel 8 = Td5 9 (steering/transmission) 1 = RHD, 4 speed 2 = LHD, 4 speed 3 = RHD, automatic 4 = LHD, automatic 5 = RHD, 4 speed & overdrive 6 = LHD, 4 speed & overdrive 7 = RHD, 5 speed 8 = LHD, 5 speed 10 (model variant/model year?) A = up to 1983-1984 B = 1985-1987 E = 1988 F = 1989 G = 1990 H = 1991 J = 1992 K = 1993 L = 1994 M = 1995 N = 1996 V = 1997 W = 1998 X = 1999 Y = 2000 1 = 2001 2 = 2002 11 (assembly location) A = Solihull F = CKD V = South Africa 12-17 (serial number Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 26, 2008 Share Posted May 26, 2008 Sorry but you have read it slightly wrong LJGAF is LJ - Discovery G - 100" wheelbase (they all are) A - this is the letter for body type your list gives Truck Cab, Soft Top or Hard Top (Utility body) F - 300Tdi engine I am not certain of the listing for the body types in your post (I think there are some others) but I am 99% certain that the Discovery 5 doors are all ...LJGBF... so I don't think you should proceed on the assumption you have made. I will try and remember to check it at work later... Quote Link to comment Share on other sites More sharing options...
maas Posted May 27, 2008 Author Share Posted May 27, 2008 Hi Yes I was wrong in my reading. So I thing is better I start thinking on changing to another 300tdi with 5 doors Thanks for you help. maas Quote Link to comment Share on other sites More sharing options...
