Graham Thomson Posted May 31, 2008 Share Posted May 31, 2008 Hi, Got the truck back yesterday.......all was well. Out late last night and went to return home to find that I had no rear (red) lights.....although the brake lights still work, as do the indicators, number plate lamp etc. Made for a tricky drive home. Is it just a loose wire? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 31, 2008 Share Posted May 31, 2008 I think it's a common earth to the side/brake lights, so it's more likely to be the live feed - especially if both lights are gone. Supply goes to the drivers side first and then across to the other side, so the fault will be from the drivers side connection forwards. Les. Quote Link to comment Share on other sites More sharing options...
