bushwhacker Posted June 4, 2008 Share Posted June 4, 2008 I took the cross member off when doing the clutch as it had took a bit of a battering off roading. I had intended to plate it up but have not been able to get it done. Would it be better to put it back on for a bit more off roading or would it be ok if left off? I have noticed a lean to the passenger side. I measured from the bottom of the arch to the outer rim of the wheel, d/s front 30cms d/s rear 29cms p/s front 27cms p/s rear 24cms Are these measurments within tolerances, 2 inches lower at the rear d/s to p/s and 1 and 1/8 lower at the front d/s to p/s. The front looks no were as bad as the back. I did have the rear springs out to paint have I put them in the wrong sides? Thanks Quote Link to comment Share on other sites More sharing options...
Lars L Posted June 5, 2008 Share Posted June 5, 2008 Driver side springs are a little longer, it's a Land Rover thing... But the difference at the rear seems to be a bit excessive, maybe the springs have done their best? Quote Link to comment Share on other sites More sharing options...
