stripy Posted June 5, 2008 Share Posted June 5, 2008 I think my last reading on my dipstick the level has gone up, would i be right in thinking the lift pump may be at fault. 300 tdi auto 98 Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted June 5, 2008 Share Posted June 5, 2008 I think my last reading on my dipstick the level has gone up, would i be right in thinking the lift pump may be at fault.300 tdi auto 98 No ... Is it possible that you took your first reading when the engine had settled for a short period, say half an hour, and the last reading when it hd settled over night ? Diesel does enter the oil, but if its a large amount quickly then normally there are other more obvious signs to notice like the engine running carp. Quote Link to comment Share on other sites More sharing options...
lynall Posted June 5, 2008 Share Posted June 5, 2008 Only way derv can get into a tdi sump is through the lift pump, rub the oil between your fingers and smell it. TDI are a painto check the oil on best way is to let it stand overnight. 200 even harder takes an age to drain and settle Lynall Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted June 5, 2008 Share Posted June 5, 2008 No, a 300tdi will not add to the oil level even if the pump is at fault. You must be misreading the level somehow. Quote Link to comment Share on other sites More sharing options...
jimmy_neutron Posted June 5, 2008 Share Posted June 5, 2008 No, a 300tdi will not add to the oil level even if the pump is at fault. You must be misreading the level somehow. Think his dipstick tube is slipping jim? Or was that just a 200tdi issue ? Quote Link to comment Share on other sites More sharing options...
stripy Posted June 5, 2008 Author Share Posted June 5, 2008 i will take a few more readings and let you know the outcome. fingers crossed it's me Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted June 5, 2008 Share Posted June 5, 2008 Yes that was a 200tdi issue only - the 300tdi does not have that problem. Quote Link to comment Share on other sites More sharing options...
stripy Posted June 17, 2008 Author Share Posted June 17, 2008 you was right jim, must have miss read it , i have kept a keen eye for a few weeks and all is fine B) Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted June 18, 2008 Share Posted June 18, 2008 on the 300Tdi the dipstick tube breaks in half instead Quote Link to comment Share on other sites More sharing options...
