oldman Posted June 5, 2008 Share Posted June 5, 2008 hi i have bought my first rr at my ripe old age,and my knoledge of them can be writen on a stamp,so i was wondering if any of you guys could help me.i have a 1998 4.6 hse and it is pulling to the near side,tracking and tyres have been checked and it is also listing on that side.Would a dodgy hieght sensor have anything to do with it,it has a air leak sometimes? yours thankfully. Quote Link to comment Share on other sites More sharing options...
Guest noggy Posted June 6, 2008 Share Posted June 6, 2008 suspension could be the problem, but not necessarily a leaking air spring, take it to any Land Rover workshop they should be able to but it right very fast.. so youve checked... Tyre pressure Uneven brakes the high from level floor to bumper on each corner tracking (are you very fat, and it weights one side of the vehicle down....) wheel bearings might also have a contributing factor. you should jack it up, and push/pull each wheel to see if there is any play in the bearings. hope that helps! Quote Link to comment Share on other sites More sharing options...
grumbleweed Posted June 6, 2008 Share Posted June 6, 2008 sounds like a sticking caliper to me- have you been through water and then parked it up for a while> Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 7, 2008 Share Posted June 7, 2008 Pulling to one side is either brakes as mentioned above, tracking (checked) or a wheel bearing on its way out. Quote Link to comment Share on other sites More sharing options...
newbieUK Posted June 8, 2008 Share Posted June 8, 2008 Pulling to one side is either brakes as mentioned above, tracking (checked) or a wheel bearing on its way out. I had the same problem on my 99 p38 that turned out to be the tyres even though they looked fine.... easily ruled out by swapping the 2 front tyres around to see it is starts to pull in the opposite direction. Quote Link to comment Share on other sites More sharing options...
