RobDef90 Posted June 15, 2008 Share Posted June 15, 2008 Quick question.... I am fitting a Safari Snorkel to a 300tdi, however I have the wrong hose piece, don't ask how.... It will fit if I remove the water trap piece piece, i.e. go straight from the snorkel to the filter housing....should i remove the piece? http://www.safarisnorkel.com/guides/LAND%2...S550HF_full.gif It is shown in the above image...... thanks for any help....Rob Quote Link to comment Share on other sites More sharing options...
Andrew Chua Posted June 15, 2008 Share Posted June 15, 2008 it will work, but i won't risk it. although the safari snorkel has some technology to expel water being taken in at the top, it's a 2nd layer of protection should any water go down. However, the air filter too, should also stop a little water from going into the engine but in the long run it's not an ideal situation. Try to fit the pieces correctly and you can live with a peace of mind that it's been done the right way. Quote Link to comment Share on other sites More sharing options...
ozzie1989 Posted June 15, 2008 Share Posted June 15, 2008 You will get different comments on this... if you plan to go deep wading I'd be inclined to take out the water trap as it's another source of water entry especially if the rubber goes brittle. It looks like you've been provided with an earlier type snorkel which has a pipe straight through to the air box Quote Link to comment Share on other sites More sharing options...
RobDef90 Posted June 16, 2008 Author Share Posted June 16, 2008 Your right, It is the older style, Arbil were selling them off...a lot cheaper than the 300tdi ones...and all that was different was the pipe, So i figured I could bodge something....I will maybe buy a length of pipe...from somewhere Thanks for the advice.....Rob Quote Link to comment Share on other sites More sharing options...
