draper40 Posted June 16, 2008 Share Posted June 16, 2008 Hey, As i have 3 seats in the front and so no cubby box, I struggle with space to put things such as keys, drinks etc. The mudstuff tunnel looks like an ideal solution but it is for the r380. Any storage ideas? Pete Quote Link to comment Share on other sites More sharing options...
Ben_J85JTY Posted June 16, 2008 Share Posted June 16, 2008 Hey,As i have 3 seats in the front and so no cubby box, I struggle with space to put things such as keys, drinks etc. The mudstuff tunnel looks like an ideal solution but it is for the r380. Any storage ideas? Pete I have fitted a couple of nets on the headlining on mine, which are really handy for maps and smaller bits, not so great for a mug of tea tho! Mobile Storage Systems sell them IIRC. Quote Link to comment Share on other sites More sharing options...
draper40 Posted June 16, 2008 Author Share Posted June 16, 2008 That was my thinking and I'm already sorting that. It is mainly the floor level stuff0- cups etc. Pete Quote Link to comment Share on other sites More sharing options...
mmgemini Posted June 16, 2008 Share Posted June 16, 2008 Do you mean something like his ??.... Note Mini door pocket in front of gear lever. Made from old plywood. The sizes are here. The carpet holds everything in place by the gear lever gator. Roof nets. Quote Link to comment Share on other sites More sharing options...
draper40 Posted June 16, 2008 Author Share Posted June 16, 2008 That looks like a good start mike. I was thinking it may be possible to sink in a couple of holes and then a pair of cup holders. Pete Quote Link to comment Share on other sites More sharing options...
mmgemini Posted June 16, 2008 Share Posted June 16, 2008 Yes Pete, Why not. The only measurements you need from mw are the length and the length of the hole. All the others you can make to suit your needs....... Mine is cut away on the left to give clearance for the battery master switch. Now that I'm moving the master switch I'll be able to make that bit a bit bigger. mike Quote Link to comment Share on other sites More sharing options...
draper40 Posted June 16, 2008 Author Share Posted June 16, 2008 Where are the measurements? Pete Quote Link to comment Share on other sites More sharing options...
mmgemini Posted June 16, 2008 Share Posted June 16, 2008 Third pic down The 17 3/4 vis the overall lenght. The 3 3/4 is from the front to the front of the hole. Make a card template to get the holes size correct. HTH mike Quote Link to comment Share on other sites More sharing options...
draper40 Posted June 16, 2008 Author Share Posted June 16, 2008 And just to make sure, that is a lt77? pete Quote Link to comment Share on other sites More sharing options...
mmgemini Posted June 16, 2008 Share Posted June 16, 2008 Wooops Nooo It's a 380. The principle is the same. mike Quote Link to comment Share on other sites More sharing options...
Godlykepower Posted June 16, 2008 Share Posted June 16, 2008 Pete, just lose that centre seat man! I bet you use that centre seat once or twice a year? You will use a cubby box every single time you get in your vehicle. Get a nice security cubby with cup holders & nets etc, and thats it, done for life. EVERY recomendation you get for this, other than a cubby box, will end up being a shortcut......you would need 2 extra dashes & a million nets all over the place to give the storage capacity of 1 cubby. I believe Mudstuff dont do an LT77 tunnel. Also, they dont really hold much, just a couple of cups & some odds & sods. More of a keep-tidy, than a bona-fide storage solution. Martin Quote Link to comment Share on other sites More sharing options...
draper40 Posted June 16, 2008 Author Share Posted June 16, 2008 Martin, I can't just lose the seat as it is a row of 3 from a Range Rover and so they are split 60/40 and so the driver and centre seat are combined. I still have the two front seats and ideally want to get round to fitting those. And they have electrics! Pete Quote Link to comment Share on other sites More sharing options...
