wozza35 Posted June 28, 2008 Share Posted June 28, 2008 Has anyone adjusted their power steering via the grub screw and nut on the top of the pas box? The reason i ask is i did it on mine but now i have a constant leak from it,i have tried instant gasket and a copper washer but it still leaks I did notice that the nut did have a plastic looking sealant on it that was hard Anyone got any solutions or ideas ? cheers warren Quote Link to comment Share on other sites More sharing options...
dantd5 Posted June 28, 2008 Share Posted June 28, 2008 Ahaaa... You got the problem I had some months ago. Friends asked me never to visit them again. I really spat oil everywhere i went. Get a rubber o- ring (ones that plumbers use - rubber) and get it on before you screw it up. Balabim... the problem is solved. I tried several sealants but none worked. Quote Link to comment Share on other sites More sharing options...
wozza35 Posted June 29, 2008 Author Share Posted June 29, 2008 Ahaaa... You got the problem I had some months ago. Friends asked me never to visit them again. I really spat oil everywhere i went. Get a rubber o- ring (ones that plumbers use - rubber) and get it on before you screw it up. Balabim... the problem is solved. I tried several sealants but none worked. Thank you ,i will try that today warren Quote Link to comment Share on other sites More sharing options...
