bloomers Posted June 29, 2008 Share Posted June 29, 2008 Hi All... This is my first post (so I must be really stuck ) I will try to explain this as best as I can, I will have to tell you the whole story so you get the gist of how it happened. My engine is a 3.5 V8 with a flapper type efi system... Today I went off roading and there I saw a lovely steep hill, done it many times before, nearly got to the top and you guessed it, The v8 ran out of puff... So the engine stalls and off I go backwards, brakes didn't hold slipped down the hill, didn't have enough time to put it in reverse, so to slow up my descent I let the clutch up engine goes into reverse and I end up at the bottom in one piece... Try to start the engine, fire's up for a second then dies fire's up again then dies, etc etc... So up comes the bonnet & after a fudge around, I disconnect the air meter & try & start, then as if by magic it fires and runs, but very rich, but it runs & gets me home with a trail of black smoke behind & the fuel gauge going down at a rapid rate of knots ... I try another air flow meter same thing, fires up stops, fires up stops, disconnect, runs but rich, next thing to try a spare ECU no difference... So its a bit of head messier where do I go from here...? Any ideas on the problem would be appreciated... Thanks... Quote Link to comment Share on other sites More sharing options...
steve_d Posted June 29, 2008 Share Posted June 29, 2008 Silly thought. Have you tried connecting the flapper while the engine is running? Steve Quote Link to comment Share on other sites More sharing options...
bloomers Posted June 29, 2008 Author Share Posted June 29, 2008 No I haven't tried that, good idea, Thanks... I did try disconnecting the air pipe from the air flow meter on the plenum side & holding the flapper half open with a piece of rag while still wired to the ECU, it did run, as soon as I took the rag out it stalled... Its a Funny one...!!!! Quote Link to comment Share on other sites More sharing options...
Bull Bar Cowboy Posted June 29, 2008 Share Posted June 29, 2008 Its probably nothing to do with the AFM ………………. Sounds like the coolant sensor has either died or there is a wiring fault to it…………… probably the latter………. if the ECU sees the coolant sensor as an open circuit then it will think your coolant temp is at least -40C so it will run more than a little rich ………. if at all……. Standing with the bonnet open, the coolant sensor is on the right front of the inlet manifold (by No 1 cylinder)……….. it is the blue topped sensor, the other is the thermotime switch which has a brown top. Ian Quote Link to comment Share on other sites More sharing options...
bloomers Posted June 29, 2008 Author Share Posted June 29, 2008 Thanks for that advice Ian.... I've got a spare engine with the coolant sensor still on it... will give it a go... Cheers Steve... Quote Link to comment Share on other sites More sharing options...
steve_d Posted June 30, 2008 Share Posted June 30, 2008 Don't fit the sensor just plug it in and see if it fixes the problem. If it does you can fit it. They can be a pig to do so worth proving the point first. Steve Quote Link to comment Share on other sites More sharing options...
bloomers Posted July 1, 2008 Author Share Posted July 1, 2008 I've fixed it... Had another fiddle, found it must have back fired when I went backwards down the hill, there's a bung on the inlet pipe to the plenum it popped it out So it was drawing air in past the AFM... Hence it would run when I unplugged the AFM... Chucking in loads of fuel... Quote Link to comment Share on other sites More sharing options...
