Landy Ally Posted July 4, 2008 Share Posted July 4, 2008 I changed panhard bush recently, but when I tried to refit the bar it is really hard to get it to line up with the hole. I tried to hit it with big hammer but wouldn’t go, so I used a jack to push it up but it not lining up with the hole. I put the other end of the bar in position and tightened it up 1st. I haven’t moved the steering, so I can’t understand why it’s not close to the hole. It has to be half an inch out to the right as you look at it from the front. Any ideas greatly appreciated. Cheers Ally Quote Link to comment Share on other sites More sharing options...
western Posted July 4, 2008 Share Posted July 4, 2008 You need to twist the steering to get the bolts & holes to align, even though the vehicle/steering hasn't moved, the axle has because it's location bar is disconnected, I had the same problem when I changed my panhard rod bushes a few months ago. Quote Link to comment Share on other sites More sharing options...
Landy Ally Posted July 4, 2008 Author Share Posted July 4, 2008 Cheers nice one. I did think of trying that but didnt want to move steering as it may get worse. Thank you Ally Quote Link to comment Share on other sites More sharing options...
western Posted July 4, 2008 Share Posted July 4, 2008 it will work, you can only get it 50% wrong Quote Link to comment Share on other sites More sharing options...
Landy Ally Posted July 4, 2008 Author Share Posted July 4, 2008 Ha ha yes your right. Quote Link to comment Share on other sites More sharing options...
