russ3120 Posted July 11, 2008 Share Posted July 11, 2008 What is the easiest way to fit a tyre back on a rim manually? Quote Link to comment Share on other sites More sharing options...
nige90 Posted July 11, 2008 Share Posted July 11, 2008 Two or ideally three tyre levers and lots of lube. Get one side keep the bead in the valley of the wheel and lever very small amounts. The third lever helps hold the non working side still. Just be careful not to pinch the ruber or bend kink the beading wires. Not too hard really. Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted July 11, 2008 Share Posted July 11, 2008 What is the easiest way to fit a tyre back on a rim manually? Russ Can't you take it into work? Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted July 11, 2008 Share Posted July 11, 2008 i do all my own tyres with 2 tyre leavers and a bottle of washing up Quote Link to comment Share on other sites More sharing options...
russ3120 Posted July 11, 2008 Author Share Posted July 11, 2008 RussCan't you take it into work? Walfy the MTO is a saxo driver and wont let anyone use any of the facilities for civi vehicles Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted July 11, 2008 Share Posted July 11, 2008 Walfythe MTO is a saxo driver and wont let anyone use any of the facilities for civi vehicles Saxo driver says it all. Same here, workshop is run by civvies and helpful as they are with the loan of some tools and the airline when I desperate they don't give much away . But I'm working on it . Quote Link to comment Share on other sites More sharing options...
clbarclay Posted July 11, 2008 Share Posted July 11, 2008 A couple of tyre leavers is the basic requirement. Lube is a good, you can use washing up liquid, but proper tyre soap is far superior. Having got some proper tyre soap a few years ago, the differance between it and fairly liquid makes you wounder why you didn't get some sooner. Quote Link to comment Share on other sites More sharing options...
