disco rear spring or 90 rear spring
i'm in the middle of putting the disco rear axle on to my 90 was thinking of putting the disco rear springs on as the a bit taller with some +2" shocks as well.
didnt know weather there going to be too strong to give me full travel when cross axled
thay would be good for the towing side. but i have been doing so much better this year with my RTVing i dont want to be at a disadvantage.
what you you all think, disco spring or keep with the 90 springs
also would it work putting +2" shocks on without a lift( i was going to fix the top of the spring).
If they are standard Discovery Springs you may actually find they are softer than the standard 90 springs.
I have just replaced the standard Green/brown ANR3447 Discovery springs with Defender NRC9448 Blue/reds as they are about 10Lb/in harder than the Discovery springs but approximately the same free length.
Data taken from Here
HTH
