Guest WALFY Posted August 4, 2008 Share Posted August 4, 2008 At 7S recently with J33P club I managed to spin my clutch very badly. Well enough for people about 25-30m away to smell it . After this incident the biting point moved to the top of the pedal travel, ie less than 1/2" of movement and the clutch disengaged enough to change gear/lose drive. I replaced the clutch and the biting point is still in the same position. I didn't touch the fluid side of things though. Is there a need to bleed the clutch even though I haven't opened the fluid system. 1 thing I did notice was the little plastic clip that holds the rod from the slave cyl to the fork was all misshapen and melted where it got a little warm . Would the heat transfer done anything to the slave cylinder itself and caused this problem or do I just need to bleed the clutch? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 4, 2008 Share Posted August 4, 2008 I'd bleed the clutch and see if it improves anything first off. Mo Quote Link to comment Share on other sites More sharing options...
