Spot Posted August 5, 2008 Share Posted August 5, 2008 Hi all Been reading stuff on here for a while but first post. I have been trying to bleed the brakes on my LSE. Fronts were fine but when bleeding the power circuit, there was only a trickle of fluid on the N/S rear, while there is nothing at all from the O/S rear. Any ideas? I am using the Haynes manual for the process of bleeding, using an eazi bleed kit, with the ABS pump running. I really do need some help, so thanks in advance. Regards Spot Quote Link to comment Share on other sites More sharing options...
Orange Posted August 5, 2008 Share Posted August 5, 2008 There's a pdf download on bleeding an ABS system in the Tech Archive........ HERE Hope it helps... Quote Link to comment Share on other sites More sharing options...
steve_d Posted August 5, 2008 Share Posted August 5, 2008 Take the bleed nipples out and check that the hole is not blocked with muck. Seen it many times. Steve Quote Link to comment Share on other sites More sharing options...
Spot Posted August 5, 2008 Author Share Posted August 5, 2008 There's a pdf download on bleeding an ABS system in the Tech Archive........HERE Hope it helps... Thanks for that, however it is almost word for word what is in the haynes manual. I am beginning to worry a bit now because I unscrewed the rear brake pipes from the booster unit and no fluid came out. Does this mean the booster unit is the problem or is there something I've missed? (I also checked the pressure reducing valve, there is fluid under pressure going in and comming out!) Spot Quote Link to comment Share on other sites More sharing options...
