Modchop Posted August 18, 2008 Share Posted August 18, 2008 Can any of you knowledgeable souls tell me what the minimum thickness of a brake disc should be before it needs changing/become's dangerous ? It's a Td5 110 CSW (2002) Thanks Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted August 18, 2008 Share Posted August 18, 2008 From RAVE, it says they can be "reclaimed" (skimmed) to a minimum of the following, so i'd assume this is as far as they can be worm down to as well... Non vented discs 12mm (0.47") vented 22mm (0.9") Quote Link to comment Share on other sites More sharing options...
Modchop Posted August 18, 2008 Author Share Posted August 18, 2008 From RAVE, it says they can be "reclaimed" (skimmed) to a minimum of the following, so i'd assume this is as far as they can be worm down to as well...Non vented discs 12mm (0.47") vented 22mm (0.9") Thanks for that, much appreciated. Quote Link to comment Share on other sites More sharing options...
