defender DK Posted August 24, 2008 Share Posted August 24, 2008 Can anyone help me out with this, I'm frequently being troubled by the fuel return pipes working loose on the injectors,it's difficult to spot because the fuel leaks only when the engine is running,which can be a problem if i'm driving for a few hours,is there a cure to stop them working loose,and as anyone else had the problem,it's a 200 TDi. Also my starter spins reapeatedly and only engages the fly wheel every second tuesday of the month!!!! could it be teeth missing off the ring gear. Any help would be appreciated. thanks Quote Link to comment Share on other sites More sharing options...
Les Henson Posted August 24, 2008 Share Posted August 24, 2008 Have you tried replacing the sealing washers on each banjo bolt (2 on each one)? Perhaps a very small amount of thread locking compound on the thread would work. The only way to check the flywheel ring gear is to remove the starter and slowlt turn the engine by hand in order to inspect the teeth. Could be the starter solenoid sticking, or the arm that throws the starter dog fowards. Les. Quote Link to comment Share on other sites More sharing options...
defender DK Posted August 27, 2008 Author Share Posted August 27, 2008 Have you tried replacing the sealing washers on each banjo bolt (2 on each one)?Perhaps a very small amount of thread locking compound on the thread would work. The only way to check the flywheel ring gear is to remove the starter and slowlt turn the engine by hand in order to inspect the teeth. Could be the starter solenoid sticking, or the arm that throws the starter dog fowards. Les. Thanks Les, the starter is coming off this weekend,I've just not had the time to do and at 250quid for an exchange unit in Denmark, I dont really want to believe its broken!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
