SiWhite Posted August 15, 2005 Share Posted August 15, 2005 Hi guys, The rear propshaft on the 90 has given up the ghost. I could just get a straight replacement - it's a Tdi mounted to a LT77. Would a TD5 shaft fit? I have heard that they offer a bit more movement on the UJs before they bind. And would there be any benifit in fitting a double cardon shaft? Si Quote Link to comment Share on other sites More sharing options...
white90 Posted August 15, 2005 Share Posted August 15, 2005 Hi guys,The rear propshaft on the 90 has given up the ghost. I could just get a straight replacement - it's a Tdi mounted to a LT77. Would a TD5 shaft fit? I have heard that they offer a bit more movement on the UJs before they bind. And would there be any benifit in fitting a double cardon shaft? Si rear TD5 ones are the same as TDi ones FRC 8393 it is the front that are different. no need for a de carden on the rear the angle is ok. a wide angled variant will be of use if you have Very long travel suspension Quote Link to comment Share on other sites More sharing options...
SiWhite Posted August 15, 2005 Author Share Posted August 15, 2005 Tony, that's great. Confirmed what I thought. Si Quote Link to comment Share on other sites More sharing options...
