foxy Posted September 16, 2008 Share Posted September 16, 2008 how to bleed a radiator must be block because water is not going around come back out of the header tank lot of thanks foxy Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 16, 2008 Share Posted September 16, 2008 What engine? Radiators don't usually need bleeding. If water isn't circulating through it, then it's either blocked or thermostat is stuck. Les. Quote Link to comment Share on other sites More sharing options...
foxy Posted September 16, 2008 Author Share Posted September 16, 2008 What engine?Radiators don't usually need bleeding. If water isn't circulating through it, then it's either blocked or thermostat is stuck. Les. its 2.5 tdi 300 what happen is going long the road and the header tank whent put a new one on the water in the tank is a lot of back pressure going to look at that and flush out the radiator out but will it be the haed gone? all the best foxy Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 16, 2008 Share Posted September 16, 2008 The simple test for a blown head gasket/cracked head perhaps, is to take the top off the header tank (when the engine is cold), start the engine, and if water is immediately pushed out, or there is constant stream of bubbles in the tank, then the gasket/head has gone. Les. Quote Link to comment Share on other sites More sharing options...
foxy Posted September 16, 2008 Author Share Posted September 16, 2008 thanks look lilke the gasket as gone how big a job is it and how much would it cost all the best foxy Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 16, 2008 Share Posted September 16, 2008 Take the head off (no, not your's, your engines ) http://forums.lr4x4.com/index.php?showtopic=8179 Les. Quote Link to comment Share on other sites More sharing options...
DiscoStu Posted September 16, 2008 Share Posted September 16, 2008 As to your original question, remove the black plastic screw (21mm) from the top of the thermostat housing and fill the engine from there with the header tank cap removed, keep an eye on the header tank level as you do. Stu. Quote Link to comment Share on other sites More sharing options...
foxy Posted September 17, 2008 Author Share Posted September 17, 2008 thanks for the replys done that so think its the head that gone more money lol lol all the best foxy Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 17, 2008 Share Posted September 17, 2008 It's vital that you get the head crack tested - even if it's obvious that the head gasket has failed. A crack test and skim (if it's needed), is only about £50. Les. Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted September 17, 2008 Share Posted September 17, 2008 As to your original question, remove the black plastic screw (21mm) from the top of the thermostat housing and fill the engine from there with the header tank cap removed, keep an eye on the header tank level as you do.Stu. Black plastic screw I hate them almost as much as KanNot filters Get thee to a plumbers shop and fit brass plugs, or even a cast iron stop end before it blows out and takes your engine with it. Buy two, one for the radiator as well on a 300Tdi Quote Link to comment Share on other sites More sharing options...
foxy Posted September 17, 2008 Author Share Posted September 17, 2008 Black plastic screw I hate them almost as much as KanNot filters Get thee to a plumbers shop and fit brass plugs, or even a cast iron stop end before it blows out and takes your engine with it. Buy two, one for the radiator as well on a 300Tdi well do you think that i should do the things i was going to do or will it be a a bad thing Quote Link to comment Share on other sites More sharing options...
foxy Posted September 18, 2008 Author Share Posted September 18, 2008 i ask some one how much it would cost and he said 1000.00 Quote Link to comment Share on other sites More sharing options...
Les Henson Posted September 18, 2008 Share Posted September 18, 2008 A grand to remove a 300TDi head, get it crack tested and maybe skimmed, necessary gaskets/bolts/etc, and put it back together is about £100 for the parts/crack test/skim. It's ok if you're happy to pay £900 for some grease monkey to take it apart and put it back together (maybe 5- hours total labour) Les. Quote Link to comment Share on other sites More sharing options...
foxy Posted September 20, 2008 Author Share Posted September 20, 2008 just got a haynas manual so going to try to do it will let you all kown how i get no sound hard put looks ok in the book chrees foxy Quote Link to comment Share on other sites More sharing options...
