basquen Posted September 19, 2008 Share Posted September 19, 2008 Hi, Just stripped down the door on Disco 300tdi to investigate failed lock. The culprit is the plastic ring at the end of the lock barrel. It has cracked in two. Unlocks OK but can't lock because crack opens up when key turns clockwise. Over optimistically tried super glue but no good. Any ideas ? I never use the passenger lock because the alarm always starts growling so could swap barrel but given that the drivers side one is marked RH I guess they're not 'swapable' ? Nick Quote Link to comment Share on other sites More sharing options...
karlo Posted September 20, 2008 Share Posted September 20, 2008 Same thing has happened to mine, According to LR you have to buy the whole door handle assembly Quote Link to comment Share on other sites More sharing options...
basquen Posted September 26, 2008 Author Share Posted September 26, 2008 Looks like it's off to search the breakers this weekend ! Quote Link to comment Share on other sites More sharing options...
